Does anyone elses oil injector pump move on the nq 50?
Posted: Sun Jan 31, 2016 1:14 pm
by OntarioBrapNq
Bolts tighten right down, still tinny bit of side to side play is she normal? Please I wanna ride lol just welded a yz 80 pipe to her.
Re: Does anyone elses oil injector pump move on the nq 50?
Posted: Mon Feb 01, 2016 7:55 am
by OntarioBrapNq
Please someone?
Posted: Mon Feb 01, 2016 8:40 am
by MrJumps
check for an o ring and that the shaft dosnt have anyplay.
Posted: Mon Feb 01, 2016 7:23 pm
by jerz40
I have worked on dozens of Honda Sprees and don't usually see them move a little when running, I would pull it back out and just double check, usually there is an o ring and I believe the rod attached to the pump is suppose to be well connected to it, as I've saw some before that just fall out. Hope this helps, good luck!
Posted: Mon Feb 01, 2016 8:25 pm
by OntarioBrapNq
My screw is tightened all the way but no clue about the o ring for sure it's in there.. Idk it just has the a bit of play and it worries me i'm losing crankcase compression due to it moving around a little.
