[edit]: Contessa Suddenly "Bogs" - Help
Justinmarldizah
Post by Justinmarldizah »
So had these bore for almost 4 months 72cc contessa I was going to work full throttling, suddently bogs and only ran with little throttle, If i full throttle makes a boggy sound and shuts off. Only way i could run it is with the choke up.
MrJumps
Re: Help
Post by MrJumps »
Airleak, check for ripped seals, leaks, and oil plug, carb boot rips. Look around exhaust for oil leaking from exhaust.
2021 DRZ400sm :worship:
Meloshameless
Re: Help
Post by Meloshameless »
Maybe something clogged main jet. Dodo gas.
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
Justinmarldizah
Re: Help
Had leaked on exhuast hole, and carb has mynah leak on the sides
Justinmarldizah
Re: Help
And had rip spigget
Meloshameless
Re: Help
Step 0 -obtain $200
then continue steps 1-6
corsa
naruku
zx trans
Yasuni C16
MrJumps
Re: Help
Post by MrJumps »
Just hondabond it all and paint over it... like new :2thumbs:
Lol jk buy a new boot, new muffler gasket, and a carb rebuild kit, clean the carb good, then clean it up and watch for leaks.
veedubh20
Re: Help
Post by veedubh20 »
sound like pilot jet little to big.
look at the spark plug
I love jog over dio... :lol:
benji
Re: Help
Post by benji »
I think the ct mani might be it, if you have one. I sanded the mating surfaces, made new gaskets, and bonded it all together. W. New boot it should be brand new, no need for a $500 shopping list.
Although, a 28mm might be too big if you do have one. But I think 24mm is too, especially w a power jet carb. I'd go 21mm.
TinyElvis
Re: Help
Post by TinyElvis »
It sounds like a air leak to me. Boot most likely. I've had a a few go on me in the past.
I ran a Corsa/PGlong/28OKO for 2 years solid, no problems (Fast too). Bulletproof!
Then I started running in the canyons and I overheat'd the sum'o'bich!
Honda DIO 3 ZX Live, Malossi, WindJammah!
Re: [edit]: Contessa Suddenly "Bogs" - Help
You will get more attention AND decrease the time wasted by Forum members who cannot contribute if you give your thread a more descriptive title. The sudden change in performance can easily be explained by a crack forming in some rubber inlet. If it ran well before, fix the leak(s) and it should run the same as it did. As to the pilot jet or other tuning suggestions: None of these things should change Suddenly. If fixing engine's accessories do not correct the issue, consider a compression check. Maybe try that first, since it's easy.
benji
Post by benji »
"Forum members who cannot contribute "?
MrJumps
Post by MrJumps »
Did you get it running yet or figured out what is wrong exaclt and by hole in exhaust do you mean the gasket is cuprit or that it literly has a hole in it?
Justinmarldizah
Figured it out thanks
Benji axt:
Ooh, ouch, got me. That sounded harsh. I meant that by itself the word "Help" will evoke in many a feeling of sympathy and a desire to assist. But if the issue isn't more defined, guys that run Gyros and Sprees and who know little about leaks in an aftermarket intake pipe will waste time opening the thread. Everyone here can contribute, but if I know nothing about LC conversions or fork swaps for example, (and I don't) I will know to pass if the "Help" request is defined up front to be about such an issue.
