Rebuilding aero
Peteyparado
Rebuilding aero
Polini 30mm carb
Naraku mani
Scorpion stroker pipe
Stage6 CDI
5gram rollers
Keli high speed Variator
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Peteyparado
Re: Rebuilding aero
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Peteyparado
Re: Rebuilding aero
Old OKO 30mm carb an CT mani are gone as soon as my new 30mm polini carb an naraku mani arrive..
got a few more goodies also coming in.. Shout out to scooter swap shop..
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Peteyparado
Re: Rebuilding aero
Had a harder time posting pics than tuning Variator lol
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Peteyparado
Re: Rebuilding aero
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Meloshameless
Re: Rebuilding aero
On ur signature u did 94 1/4 @ 14 sec. Was that with the old oko, ct, and that rusty pg?
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
Peteyparado
Re: Rebuilding aero
At the time it was a pg stroker pipe an yeah with that OKO an ct..
The bike was in storage for a coupe of years. I'm getting back in again..
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Peteyparado
Re: Rebuilding aero
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Re: Rebuilding aero
I've seen a sleeper like this before do a crazy burnout.
I don't underestimate them.
Meloshameless
Re: Rebuilding aero
Oh d***, you bought the good shift!
corsa
naruku
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
Peteyparado
Re: Rebuilding aero
G9 already loving this new set up she runs way smothers at low rpms b4 powerband.
An she is a sleeper till they hear start up..
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Peteyparado
Re: Rebuilding aero
Yes exactly the OKO had a bad flat area... But this polini smooth right out of the box only changed MJ that's it..all action!!
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Eliterider
Re: Rebuilding aero
I wanna see a video of that pipe rev up
Peteyparado
Re: Rebuilding aero
Can can, but not till Monday Tuesday because I waiting on parts..
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
