back firing
808allday
back firing
Post by 808allday »
When I hit around 50 - 60 MPH bike starts to back fire. Could that be my main jet?
808allday
Re: back firing
Post by 808allday »
When my bike hit 50-60mph it back fires
Could it be my main jet or could it be my float in my carb.
What causes backfire anyway
Meloshameless
Re: back firing
Post by Meloshameless »
I had popping sounds when my reeds were goin out, but google search carb tuning, i wanna say backfire falls under rich condition but cant remember.
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
MrJumps
Re: back firing
Post by MrJumps »
The after fire, popping can be a LEAN condition or if it is truly backfiring through the carb it is RICH.
2021 DRZ400sm :worship:
808allday
Re: back firing
Post by 808allday »
Its backfiring from the exhaust
Re: back firing
This was explained to me by grizzled Sportster Cognscenti years ago. Under compression, the inhaled mixture is non-combustibly LEAN for several piston strokes. The fuel and air is wasted out the pipe until enough gathers in a of the header segment. After a certain number of cycles, the mass ignites at once producing the BANG!!
