Electric Start not working but Kick Start is - Yamaha Vino
Posted: Wed Apr 27, 2016 1:15 am
by treelessbark
I got a 2007 Yamaha Vino Classic 50cc that I recently purchased used on Craigslist. It runs (yay) but unfortunately it seems that the electric started suddenly stopped working, worked a little, and then stopped again.
When I push the electric start button, nothing happens (no noise or anything). When the scooter is on all the lights work fine, so not sure if it's a battery problem, but I'm guessing I could be wrong. This isn't something that I have to fix immediately, but something I would like to tinker around with trying to fix it. First step would be, where the heck is the starter and starter relay so I can check those, and how do I open the front panel, haha. Also having issues opening the box that holds the starter button on the handle bars, and any advice for that would be as well. Thanks!
Re: Electric Start not working but Kick Start is - Yamaha Vino
Posted: Fri Oct 25, 2024 9:42 pm
Check the start button then check the neutral relay works right and then check the stater solenoid. I doubt it is the battery.
