CDi settings???
Posted: Fri Dec 01, 2006 9:04 am
by BigWillieStyles
Hey guys, Im in Japan and i just fitted a new CDi unit which i highly recommend doing. Its given me some insane torque right through the rev range especially down low where it was lacking. Anyway, the instructions where all written in Kanji (japanese) and i cant understand the 4 settings it has?
Heres a picture of it, it has 4 maps? Why do they have 4, i put it on number 2 but should i put on one? I dont understand what they are for.
Posted: Fri Dec 01, 2006 9:13 am
by darat
looks like different timeing
Posted: Fri Dec 01, 2006 10:13 am
by BigWillieStyles
Would i expect to gain more if i switched to number 1. Would there be any drawbacks?
Posted: Sun Dec 03, 2006 11:28 am
by Gamemedic
It looks like Map 1 is a really advanced timing (high torque low rpm) Map 4 the timing is retarded (low torque high rpm) Map 2-3 is a happy medium. If you advance the timing all the way you have to use high octane fuel and dont run it long at high revs. Advanced timing WILL melt your piston at some point. If your doing alot of light to light driving then Map 1 wont kill ya', if not 2 or 3 is good. If your doing long distance driving then 4 will give you high end power and good gas milage.
Hope this helps.
Posted: Mon Dec 04, 2006 5:43 am
by BigWillieStyles
thanks thats great help, i do alot of drving so i try retarding, but i might have a play around w it also.
Posted: Tue Dec 05, 2006 8:14 pm
by vonchuk
If you do try to run full advance, run a colder spark plug to keep from damaging a piston. On two cycles, you always try to run the coldest plug.
Posted: Sat Dec 16, 2006 9:26 pm
by hondaspree86er
will this cdi work on a spree if not is there any that will
Posted: Sun Dec 17, 2006 12:50 pm
by Kenny_McCormic
i wonder it would be ool if u could
Posted: Mon Dec 18, 2006 8:59 pm
by Rabbi
How much was that CDI?
Posted: Tue Dec 19, 2006 9:03 am
by darat
idk it might work with the spree.
