How much oil do you run?
Karman
Post by Karman »
I built a 2001 Elite 50 back in '08 that I'm bringing back to life after not having ridden it in several years. It has a 72cc Polini Corsa, Oko 28mm carb, PG long and upgear. The auto oiler was blocked off and I've always run premix. Problem is, I can't remember how much oil I was running per gallon of gas. I do remember running a little on the heavy side oil-wise per burnt_toast's recommendation. Can anyone with a similar setup chime in with what ratio they run oil to gas?
Cmoped9
Re: How much oil do you run?
Post by Cmoped9 »
The most common is probably 32:1, which is 4oz. per gallon. Some guys may run 40:1, but 32:1 never hurts.
2000 Elite SR
Malossi Cast, 24mm Polini (36/110), 9.8 gears, Naraku intake, PG long exhaust, 6k yellow Polini clutch springs, 5g roller weights. Top speed: 60mph
Peteyparado
Post by Peteyparado »
32.1 is a happy medium
Polini 30mm carb
Naraku mani
Scorpion stroker pipe
Stage6 CDI
5gram rollers
Keli high speed Variator
6.1 gears
94mph
