crank bearings
dbkawasaki
crank bearings
Post by dbkawasaki »
whats a good crank bearing for af16? aftermarket or oem? thanks
Re: crank bearings
Honda's own NTK bearings are hard to beat. At $16 or so apiece, it's not worth risking your engine on something else.
dbkawasaki
Re: crank bearings
cool thats the kind of response i was looking for, thank you
dbkawasaki
Re: crank bearings
graphite9 wrote:I run polini evo, or stage6 SKF, just cause I don't want to change them prematurely.
beware, alot of the NTK now is out of tiawan, not true japan like most honda bearings. Joe let me in on this.
ok looks like they are in stock, the s6 anyway..ill order those instead...thabks for that heads up!
