I need 1987 SE50 carb options / suggestions.
Posted: Sat Jun 04, 2016 10:44 am
by Kustomkarma
I have been trying to get my 1987 SE50 back on the road since last August. Every time I touch something, two more things fall apart. Right now I'm to the point of putting the carb back on. So far I've gone through 3 stock style carbs, but there's always an issue, stripped threads, mismatched parts, etc. etc. The short story is that I'm sick of these stock Honda carbs! What's a good bolt on carb for a stock AF05E? I've added a Scooter Swap Shop Slick Willy pipe but that's about it. I don't mind swapping the manifold if I need to. Any suggestions would be greatly appreciated.
Thanks!
Re: I need 1987 SE50 carb options / suggestions.
Posted: Sat Jun 04, 2016 3:48 pm
The Amal-Arreche-for-Honda will bolt straight on, bystarter and all.
- arreche 21.jpg (8.96 KiB) Viewed 9808 times
You'll need a set of Pilot and Main jets that are different from PWK/OKO and Polini but unlike Honda's PA carb, it does allow you to choose the Pilot.
Posted: Sat Jun 04, 2016 6:15 pm
by Kustomkarma
Wow that looks great! Do you have info on model number, the best place to find one, airboxes / filter, etc.? I was kinda looking at the Polini Kit from Scooter Swap Shop, but I'm trying to reign in my spending on this project - if possible.
Posted: Sat Jun 04, 2016 6:32 pm
Some were available at Scooter-Center and/or 50cc.eu back when Michael Jackson was alive. Not sure they have them any more.
Posted: Sun Jun 05, 2016 3:41 pm
by Kustomkarma
Does anyone know if I can use a carb off of a SA50 (AF16) on my SE50 (AF05E)?
Posted: Sun Jun 05, 2016 5:43 pm
by benji
I think so.. but it's the same carb just slightly larger. The amal arreche or other carbs are way more tunable/serviceable IMO.
Posted: Mon Jun 06, 2016 11:31 pm
by martynkim
I have a good top side OEM carb. Use your parts make it complete.
Posted: Tue Jun 07, 2016 10:51 am
by Kustomkarma
PM'd! ^^^^
