Page 1 of 2
Do i need to mod the sb50 carb to run a BBK/muffler mod?
Posted: Wed Jun 15, 2016 9:44 pm
by Jackstickley
I know the SB50 engine is non-variated so modding it wont give the same performance boost a dio or se50 could get but i don't know where to find a good dio engine and have no welding abilities if i needed to change any motor mounts on my elite E.
So if i switch to a performance muffler and an 84mm BBk (i think is the good size). Do i need to mod the carb in any way and/or change the air intake? if so where do you recommend getting those parts?
I guess someone said a gearing kit has been released now too. so while not as good as a fancy variator it should give back some nice low rpm take off performance ill probably lose from these mods. though i haven't found it for sale yet.
Re: Do i need to mod the sb50 carb to run a BBK/muffler mod?
Posted: Fri Jun 17, 2016 12:06 am
by Jackstickley
well i guess the good BBK mods come with the widened injector so the answer is yes. now to find one that does come with it.
Posted: Sun Jun 19, 2016 3:26 pm
by benji
I would look on ebay or in the for sale section for a variated afo5 motor from an aero or a later elite. The spree motor has lot of limitations, most notably the one speed tranny. Variated afo5's are fairly cheap in comparison to an af16. I've bought one for $100 shipped, complete, and they do 40 stock. Much easier to work with.
Posted: Sun Jun 19, 2016 3:36 pm
by benji
I put this motor together for about $650 including the cost of the motor. Has a polini bbk, 21mm stage6 pwk carb, burial expansion chamber, ncy quick throttle, malossi drivetrain,etc. Not crazy fast but fun around town, top speed 45-50 or so.
Posted: Sun Jun 19, 2016 5:02 pm
by Jackstickley
ive been looking for engines for sale no real luck. maybe i just found one on this forum for sale. im assuming the variated afo5 wont need any motor mount welding to get a proper fit in the frame?
Posted: Mon Jun 20, 2016 12:57 am
by benji
Not %100 sure, but even if you have to make a custom mount it's well worth it.
Posted: Mon Jun 20, 2016 1:02 am
by Jackstickley
i think i have a lead on a 01 elite s in good condition so right now the plan is to get that after ill either sell this elite e or keep it as a slow project.
Posted: Mon Jun 20, 2016 1:10 am
by benji
If you pick up the newer elite that'll be an af16 motor and a definite winner... lots of parts available and easily found. If you do pm me I need some elite e panels I might just buy the whole scooter from you.
Posted: Mon Jun 20, 2016 1:15 am
by Jackstickley
The panels on my current E aren't very pretty, i bought it with the idea of turning it into a skeleton scoot so i didn't pay them much mind. but i could use the money. would guarantee i get the 01 S.
Posted: Mon Jun 20, 2016 7:19 am
by benji
Lemme kno, I'm filling my backyard up pretty fast these days w broken down scooter projects haha.
Posted: Wed Jul 13, 2016 5:20 am
by Jackstickley
I've decided to take what i have and make it the best i can, even with its limitations it should do what i need it to do. the Taz gears will be the last thing i do. muffler is on the way. bbk/jet are next and i'm assuming i will have to mod the carb/intake soon after. I wanted a project and i got it lol.
plastics are still on for the moment but i will keep you in mind if they ever stay off.
Posted: Wed Jul 13, 2016 6:49 pm
by benji
Whatever bbk you get should come w a jet in the kit, if not there's jet kits for oem carbs from naraku
Posted: Thu Jul 14, 2016 4:07 pm
by Jackstickley
yes the Taz BBK comes with the 100 or 107 fuel injector and after i install the kit i will either need to remove the oil injector and run premix or force it to full blast and still run premix gas(especially during break in).
but im still not sure how much i will have to mod the stock air intake. and not sure a uni filter will work well if i don't have the 21mm taz carb/intake kit.(which wont be for sale for a few more months.)
Posted: Fri Jul 15, 2016 3:11 am
by benji
I wouldn't do a uni if you've gotta stock carb... you can get oem filters from polini and molossi, and you can get little round filter plugs for your airbox to make more air inlets
Posted: Fri Jul 22, 2016 10:28 pm
by Jackstickley
Other than injector port what would need to be modded carb wise? Does taz's 22mm carb mount do more than widen the channels?
Dumb question: assuming i keep the gears stock in my non variated afo5 what would the 48mm bbk do to its performance? Would it raise my accel and hill climbing abilities? Or just raise top speed by small margin?
