help with scooter dying
Peteyparado
Re: help with scooter dying
95mj on 50cc sounds super rich to me... High pitch zingy sound is lean.. Crapping dead dull sound rich
Not sure what a stock jet size is but mayb 2-3 up jet from stock because of your pipe..assuming no air leaks
Polini 30mm carb
Naraku mani
Scorpion stroker pipe
Stage6 CDI
5gram rollers
Keli high speed Variator
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
- tazland001
A 21mm carb and a V8 on a stock cylinder? Are you running a BBK?
Taz
Taz
Peteyparado
Have u check your compression.. U running oil pump I asume? I had a guys scoot I was fixing stock scoot he could run all day aslong as he doesn't hit full throttle for a long period than it would die soft seize.it would start up an go.. Anyway his oil pump throttle cable was stretched an wasn't getting th prop lube.. Mite be somthing to look at..
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Sounds like an air leak to me.
Peteyparado
U remember what your squish Clearence was? Try 32.1 premix sparkplug temp u using.. I think if everything is ok.leaks,comp,squish,piston,ring gap.etc..U just gotta find the right jet till she runs good..trial an error...
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
I might be wrong, but your bike seems like it needs a big bore. You've got a big carb, big mani, big reed cage, big pipe, but small cylinder. I bet w a larger cylinder it'll run better, 49cc is designed for much smaller, more restrictive stuff. Open it up to much and you won't have enough vacuum to pull gas out the jet.
Good compression and no leaks anywhere in the block is good. Sometimes the leak is at the carb mount, or (in my case) a forgotten rubber plug over the oil spigot. If the jets are waay rich and still your engine gets too hot (assuming the fan is installed...) it's pulling in extra O2 from SOMEwhere.
Peteyparado
Try taking the head off an double checking everything.. Sounds like a unforeseen issues.. Did I try 32.1 maybe a colder plug..what kind of temp gauge u using? Maybe faulty
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
1man8scoots
Why don't you try putting a stock carb back on trains420? Seems like a lot of work for something you can't make work.
1man8scoots
Nothing offending me. Just interested what the goal is of using a large carb on a stock bore. What's the max speed you've seen vs when it had a stock carb?
1man8scoots
If youre trying to get something good from my reply take my sagelike advice and run a stock carb on a stock bore. No convoluded message there.
You're the one who can't tune this carb. Not me. I have more common sense than to use a 21mm oko on a 49cc vert honda.
Too funny and walking away laughing now. Bye bye trains420
1man8scoots
You're not a new user. Trains420. Come on with the threats kid.
