Anyone got a pic of a polini CP carb on their Spree?
Weezerjerry
Post by Weezerjerry »
I want to make sure things are connected up properly and was hoping someone might be able to post a pic of a polini CP carb on their Spree.
I have a tazz BBK and a polini CP 19mm carb. Am hoping to get it all back together and running and tuned this weekend.
Thanks for the help!
Weezerjerry
Re: Anyone got a pic of a polini CP carb on their Spree?
I am asking this because the Polini carb seems to have many places for connections. All I have connected to it currently is the fuel lines. Does this mean I need to somehow cap off the other nipples on the carb?
Peteyparado
Post by Peteyparado »
Just fuel line an vacuum for petcock..
Polini 30mm carb
Naraku mani
Scorpion stroker pipe
Stage6 CDI
5gram rollers
Keli high speed Variator
6.1 gears
94mph
MrJumps
Post by MrJumps »
19mm cp is an amazing carb, first starts like nothing and runs smooth my jets are lean probably 10 jet sizes and it runs fine. Heads up though to first prime it on the spree petcock ive seen people completely choke the carb until your hands soaked then wot until it starts and let off and it should idle fine from package. The 2 nipples pointing up need to be capped off.
2021 DRZ400sm :worship:
