1986 spree crankcase gasket thickness
I need to know the thickness of a 1986 nq50 crankcase gasket so I can get the proper sized gasket material to make a gasket.
- eclark5483
Re: 1986 spree crankcase gasket thickness
Taz was selling gasket kits on eBay, don't know if he still is. Would make more sense just to buy one over trying to make one.
FunkeyMonkey
They were like $5 last time i saw them on ebay
2001 Honda Elite 50
72cc malossi cylinder
24mm polini carb
Naraku intake
24mm polini carb
Naraku intake
yeah but they have gasket material at the auto parts store and I wont have to wait for it to come in.
They are about 0.020". Auto parts are typically 0.030".
I ended up just going with the smallest stuff I could get from the auto parts store that was .030'' thick every thing seemed to go together very well. I figure I tiny bit loose is better than to tight.
- Untitled.png (246.52 KiB) Viewed 12963 times
kamikazecassidy
Did this work for you? I haven't been able to find gaskets on eBay. Thanks so much!
- vintagegarage
kamikazecassidy
Thanks for the links but didn't answer my question. Did the .030 gasket material work? I've been asking about the mini melody gaskets and no one can definitively tell me they will work. The first link is the gaskets I bought and a few of them are different from the 85. Plus one was already torn on delivery and I haven't heard back from the seller. Most importantly, if buying gasket material and making my own will work then why wait for them to come across oceans? So, did the .030 gasket material work?
Last edited by kamikazecassidy on Wed Aug 17, 2016 1:43 pm, edited 1 time in total.
- vintagegarage
Sorry.. You said you couldn't find them on ebay..I'll butt out and let wwolvert answer you on the .030 thickness working for him.
Yeah it worked great the spree runs awesome
kamikazecassidy
Thank you SO much. I wish I had found this answer months ago.
The main impact to not having right thickness is jug base gasket. That said, another 0.010" isn't going to kill your engine. All the others... 0.030" works fine.
Getting 0.020" gasket material is a real trick; I've been unable to find it in DIY quantities anywhere.
.030/.30 what ever it is what I use and its fine so much cheaper and I can use the gasket stuff to fix anything you guys can also stack cereal box gaskets. Worked for a while for me.
2021 DRZ400sm
2021 DRZ400sm
... cereal boxes. Yes, I've used those too in a pinch.
This is getting ridiculous. I think I'm going to start producing gasket kits as well.
