Compatible parts for elite
FunkeyMonkey
Looking for 01 elite 50 coil, what other years/models use the same coil?
- mNczxblb2ypEzNDn0_WwKtQ.jpg (3.92 KiB) Viewed 3459 times
2001 Honda Elite 50
72cc malossi cylinder
24mm polini carb
Naraku intake
24mm polini carb
Naraku intake
- vintagegarage
Re: Compatible parts for elite
Funkey,
If you check online, for a 2001 SA50 coil, you will see they are still at stock at Honda:
http://www.hondapartshouse.com/oemparts ... re-harness
Then click on the link in the part number, or put the number in the search near the bottom of the page.. i.e. 30510-GS7-505 to bring up the detail page for the part, and then click on the link called "where used", and you will see that the same coil is used on SA50s from 1994 to 2001, but is not used on any other models. If it were used on something obscure, like a Honda Express, it would add it to the where used list.
FunkeyMonkey
Awesome thanks vintage didn't notice that before
2001 Honda Elite 50
24mm polini carb
Naraku intake
24mm polini carb
Naraku intake
