1987 Honda Elite 50
HondaJeese
1987 Honda Elite 50
Post by HondaJeese »
Hey guys just bought a Elite 50 Does about 30mph Looking for quick mods to help me get around that 40mph mark? Lemme know what you would suggest!
Re: 1987 Honda Elite 50
Look on the VIN sticker on the frame tube on the carb side. Does it say SE50P?
HondaJeese
Yes SE50P
The "P" means its the "restricted" version. I just went through this same process. To de-restrict you need to get a muffler, ramp plate and gears from an SE50. They say that the main jet in the SE50P "IOWA VERSION" is #82 and if you have that then it needs to be swapped with a #85. Just the Ramp plate, muffler and #85 main jet will get you to 40+ mph. However, you don't have to swap the restricted items with stock SE50 parts. You can always swap them for aftermarket stuff which is more money but will give you more gains. Picture shows the difference of the ramp plate. The left one is un-restricted.
Link below shows the difference of SE50P and SE50 parts.
http://hondaspree.net/wiki/index.php5?t ... erformance
ramp plates.JPG (120.79 KiB) Viewed 14203 times
HondaJeese
Where can i get and exhaust and ramp plate from? Seems like they are discontinued
One way is to post a "wanted" ad here in the proper section. You could also scour Ebay but there hasn't been any on there in awhile. Best way is to save a few more pennies than the old stock ones will cost you and buy aftermarket items. More bang for your buck too. This is one Ive been staring at for a few weeks....
http://www.scooterswapshop.com/collecti ... -se50-aero
Usually if I stare at something long enough it ends up in my mailbox.. :lol:
HondaJeese
What does that clutch change over stock?
eclark5483
Post by eclark5483 »
Remember to always get drunk before shopping online. You'll usually end up with all kinds of cool stuff shipped to your door.
benji
Post by benji »
I've got a ramp plate you can use. The clutch will give you better take off and engagement points, depending on how it's setup. Usually you can just swap the clutch springs out on the oem clutch w stiffer aftermarket versions, and it's basically like revving up higher before you drop the clutch. Higher engagement rpm, which usually means it'll be closer to its power band and be a Lil quicker.
