120cc port timing questions
93notch408
Post by 93notch408 »
Hi i have a 120cc stroker af16 elite im putting togeatjer and have a question about port timing it has a 56.6 stroke crank and a 54mm bore from autotech on ebay...i was wondering at b0ttom dead center i got all the ports to clear the piston but the boost port its still slightly below the crown of the piston would this be ok? My pip and head gasket should be here in a few days so i can donthe solder test for thr squash but right now im trying to figure out the port timing thank you.
1man8scoots
Re: 120cc port timing questions
Post by 1man8scoots »
Send me a pic of how far it's sitting on the fb messenger terd machine
Peteyparado
Post by Peteyparado »
I use to run that same bore with same size crank Just different brand.. But I raised the cylinder 1.80mm fully ported that motor ran 94mph.. That POP/prodigy bores are killer an last forever had mines just about 7 years on same crank an seals..
Polini 30mm carb
Naraku mani
Scorpion stroker pipe
Stage6 CDI
5gram rollers
Keli high speed Variator
6.1 gears
94mph
Ultraliner
Post by Ultraliner »
94mph?! Dude i'm surprised your seat is big enough for both you and your balls!!
Peteyparado
Was not me on scoot a friend.I'm * bricks at 87mph my max speed on my scoot
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
93notch408
So i got my pipe i got it spaced out and i still blow headgaskets its like ripping it when it blows
