I weight 180lbs. I have an SA50 elite 1994. I bought a polini variator and belt and am using the heavier weights that came with the polini. Im toping out at 42mph but have lost some low end pickup. Im sure people have experimented and know the right answer to this so i was hoping to get some input.
Thank you,
What is the ideal variator setup for elite SA50
needmoreinfo
- BMX
- Rip_City_Spree
Re: What is the ideal variator setup for elite SA50
Every bike is different you need to try different setups till you hit what you like best.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
On a stock motor I had good luck with 7 gram weights, and I'm close to your weight. Maybe try adding an aftermarket clutch or even just stiffer clutch springs. My first mods were the same as yours plus a clutch, and I did about 44-45.
Also, did you get a kevlar belt? I've heard those are a little slower than normal ones. And the polini belts are gates, I hear bando belts are slighter wider, giving slightly more top speed but I can't personally confirm that.
