Help with boot and carb issue
MrJumps
Post by MrJumps »
I tore the rubber boot from my ct mani to 21mm cp pollini trying to get the carb off it to pull the head. Air leak again...
What size boot do I need to buy and where can I nag one from, also I wanna run a better fikter on the 21mm pollini cp. Is 21mm the slide size or size of the filter mount? I am really confused on all of this I know it is fairly straight forward and simple I am just fustrated with it. I found one with pat a while back on treatland but I cant find it again and when I found boots again there not the same one and im scared to go ordering another. Does anyone know the ct boot size needed then the polini boot size needed for the 21mm cp?
2021 DRZ400sm :worship:
bonesv
Re: Help with boot and carb issue
Post by bonesv »
benji
Post by benji »
Isn't the ct mani a 32mm connection? I'm not sure on the polini, but I think if it's a pwk style carb then it'll have a 32mm connection and 21mm is the actual size of the hole in the throat.
MrJumps
Post by MrJumps »
http://www.treatland.tv/polini-carburet ... 3.0124.htm
25mm to 28mm this is the one I ordered ill make it work c:
