Hello,
I picked up an Elite E this summer for $400, it had 850 original miles on it. I rode it putting on about 100 miles on it and the back tire went flat on me. I wanted to get bigger tires, so I ordered some 3.0x10 tires, however now I'm afraid they will be too big unless I change the shock.
I guess I don't want to change the scooter too much from stock because of the great original shape it is in.
Any suggestions?
1988 Honda Elite E Tire and Shock Selection
- IMG_2070.JPG (138.51 KiB) Viewed 3507 times
- IMG_2064.JPG (85.42 KiB) Viewed 3509 times
- IMG_2072.JPG (101.37 KiB) Viewed 3509 times
Re: 1988 Honda Elite E Tire and Shock Selection
I believe the biggest tire size you can go with on these motors is 2.75-10. As Honda Elite E's and Honda Spree's motors are nearly the same, and the biggest on the spree you can go is 2.75-10. I would do just the rear tire tho. And yes keep it stock! That's one great looking machine you got there!
Install the wheel deflated and reinflate and see if it cleans right if not idk my resr is a met with 3.75-10 and you wanna talk about clearnace...
2021 DRZ400sm
2021 DRZ400sm
