What's the hottest cylinder temp you have had? *436 degF*
NZHonda
Post by NZHonda »
As the title suggest. What is the hottest cylinder temperature you have had?
Recently I had 436F at wide open throttle for an extended period of time.
Malossi 72cc Cast BBK.
The problem being that I recently changed the throttle cable as it was very stiff and sticking in places. I believe that when the bike was tuned the throttle was not opening fully. It also made it hard to start the bike as the throttle was stuck partly open.
The fix was to tape over the holes that had been drilled in the air box. At the time when the bike was tuned (pre new throttle cable) it need more air so a series of holes were drilled in the bottom of the air box. By tapping up the holes it reduced the airflow and allowed me to keep riding. Interestingly the temps dropped down to 350F max. The scooter now needs a re-tune but is useable.
Needless to say I was getting pretty worried about destroying the engine but at this stage there seem to be no problems.
So what's the max temp you guys have had? Damage?
Does anyone know when these kits/any kits actually either seize up or start melting things?
436F Scooter Temp.JPG (88.17 KiB) Viewed 6508 times
Honda DJ1R project
Re: What's the hottest cylinder temp you have had? *436 degF
oops
Ben L.
Post by Ben L. »
Crazy temps! I let off on my Malossi cast kit at 400 degrees. But now that its broken in (1200 miles) I rarely ever see those temps. I can blast for miles and not go over 350.
Flash 4 had a 78cc (49mm) Nikasil bore from DayWOT. I pulled to a halt after a short off-throttle downhill and was SHOCKED to see 550 degrees on my analog VDO gauge. Although the temp quickly declined, I wondered if it was faulty. I realized I had a lot to learn about the important role of the Pilot jet - I believe I was using an Arreche 17.5 at the time with a 15 Pilot. The Nikasil cylinder was pretty tame in terms of performance, but it sure could take abuse. I ended up with a 30 Pilot if I recall correctly.
benji
Post by benji »
Ya, I'm always revving the throttle a couple times when I decelerate or go off throttle. I don't have a gauge but I know it gets got sometimes... especially on them long straights goin 45+
Rip_City_Spree
Post by Rip_City_Spree »
I have the malossi sport cast and I can blast around wot for as long as I want and my highest temp is 350. yesterday I rode at wot up a major hill that is atleast 2 miles long and steep and 45mph road so I blast it and my temp only got to 344 with a top speed of 45. and run the * out of this bore and have yet to see anything above 350. thats with a 24mm polini carb with a 102 mj. not sure where the ceiling is temp wise on the bore but it shouldnt get to 400. my corsa that I was trying to blow up I ran it up to 450 for a very long time and that was with a broken exhaust stud and the d*** thing still ran great after.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
