1987 elite carb?
smsudad
1987 elite carb?
Post by smsudad »
Do the carbs that you see on eBay work for my elite 50s. I think they are made in China or somewhere......... They look similar but hate to invest if they are no good. Thanks. Doug
Re: 1987 elite carb?
Whats wrong with your stock carb?
jakubman1
Post by jakubman1 »
stay away from chinese parts !
smsudad
Post by smsudad »
I can't get the needle to seat properly and it's been sitting outside in an alley for couple years. Have cleaned it best I could and tried 3 needles to no avail. It just continues to leak Tried two floats also.
MrJumps
Post by MrJumps »
When you say leak, from where? Maybe your petcock has failed and is dumping fuel into your carb.
2021 DRZ400sm :worship:
benji
Post by benji »
You should look for a complete rebuild kit for your stock carb. That should cost as much as a Chinese carb and work better. I've bought 2 oem style carbs off ebay. One worked fine, one literally started dissolving itself when it was full of gasoline. I'd stick w the oem keihin if you still got it, it's probably fixable.
benji
Post by benji »
This one should work, and it's from a decent company so you can warrantee it if it's bad. But you shouldnt have to buy the whole carb, you should be able to find a rebuild kit for your carb. http://www.racingplanetusa.com/carburet ... -_hR3Tn_qA
