High idle and runaway idle? Air leak? Any help ?
Posted: Sat Oct 08, 2016 5:44 pm
by Chrisnycspree
Engine hesitates, idols high and "runaway" then bogs out? Idle adjustment isn't doing anything? I'm thinking air is getting in? Any help in trouble shooting?
Re: High idle and runaway idle? Air leak? Any help ?
Posted: Sat Oct 08, 2016 5:47 pm
by Rip_City_Spree
Bike? motor? Stock? What modifications? Clean carb? Was it running prior to issue? Need more info if you want to get help
Posted: Sat Oct 08, 2016 6:13 pm
by Chrisnycspree
Sorry 1986 Honda spree , carb just cleaned, turns over first kick...just idles super high or runs away....bogs out after a few "full throttles"...
Posted: Sat Oct 08, 2016 6:27 pm
I suspect a throttle slide issue. It must drop with ease to rest on the throttle stop screw. There is a groove in the slide and a nub in the slide bore. Any amount of force greater than the return spring will mangle both.
Posted: Sat Oct 08, 2016 6:31 pm
by Chrisnycspree
Thank you for your response!! I'll check
That tomorrow! And keep you in the loop!! I'm alittke frustrated now lol and it's raining hard
Posted: Sun Oct 09, 2016 3:18 pm
by Meloshameless
Perhaps ur air box came loose, sounds like extra air to me, try turning air screw all the way in the 0.5 turn out, that should choke it quite a bit, if that helps you have an air leak.
Posted: Mon Oct 10, 2016 12:07 am
by MrJumps
If you took the carb off how did the carb spacer look? Is that oring going okay? Mine was flattened out at one point pretty bad. Like the other user said, airbox is a big problem with the spree. Without an good filter and what not. if not runs bad.
Posted: Mon Oct 10, 2016 11:10 am
by Chrisnycspree
Thank you! The carb and 0ring looked good...I'm going to check it out again today, double check the hoses etcetc
