Intake Gasket Question
R1Titan911
Post by R1Titan911 »
I assume I can use stock intake gaskets for my Naraku? SSS is sold out, thinking of just getting some off bikebandit. Unless any of you have a source for a better quality one?
bonesv
Re: Intake Gasket Question
Post by bonesv »
R1Titan911 wrote:I assume I can use stock intake gaskets for my Naraku? SSS is sold out, thinking of just getting some off bikebandit. Unless any of you have a source for a better quality one?
Do you mean for the base only? The Naraku has 3 gaskets
R1Titan911
Sorry yes the base. Can i use stock?
But if i needed replacement gaskets for the Naraku reed cage where can i source those?
bonesv
Post by bonesv »
R1Titan911 wrote:Sorry yes the base. Can i use stock?
You can look at http://www.treatland.tv/vforce-replacem ... t-g364.htm or from http://store.mototassinari.com/index.php/gaskets.html
For the base I would say there is a good chance but as always, double check for air leaks!
On the Naraku cage, I am not 100% sure these will fit exactly but the vforce reed cage fits a ct manifold so you might get lucky here.
R1Titan911
I'm not saying i'm going to re-use the intake gasket. I just wanted to know if fitment of the stock one works so i can just buy a new stock one. Then find ones for the cage if needed. Thanks Bones!
