Honda AF24E
bootz1
Honda AF24E
Post by bootz1 »
Hey guys!
Any info/tips on the AF24E engine? looks really similar and like alot of parts for AF18 Dio engines would bolt on. Its from a 1994 Giorno I bought cheap for parts.
Any info appreciated!
-1990 Honda DJ1-RR- a work in progress....
-1988-ish? Honda DJ1-R
-1980 Yamaha V50
bonesv
Re: Honda AF24E
Post by bonesv »
Those look the same as af16 motor on our usdm Elite sa50 scooters.
What is the serial number on it?
bootz1
Re: Honda AF24E
Post by bootz1 »
Does this help?
-1980 Yamaha V50
bonesv
Re: Honda AF24E
Post by bonesv »
Yes, and that is the af16 style case which is very similar to the af18.
There were two different af24 motors which were for two different scooters.
You have the one for the Giorno.
I am not sure about internal parts fitting between the af18 and af24 but I'm sure you will let us know if you find out!
bonesv
Re: Honda AF24E
Post by bonesv »
Update: af24 case has the small diameter crankshaft on variator side (1st generation dio style).
I have seen seals that would allow for the use of af16/af18 large diameter crankshaft. I just can't remember where I saw them....... :sad:
Also there may be other differences not yet know. :eyeroll:
Re: Honda AF24E
It baffles me that Honda-san downsized to 10mm the drive end of the 1st-generation AF18's crankshaft. The fact that it went back to 12mm suggests that perhaps they encountered some failures. So why, oh why did they do it again for the AF24??
bonesv
Re: Honda AF24E
Post by bonesv »
Wheelman-111 wrote:Greetings:
I suppose there was some old stock still on the shelves to use up? Then they put that motor on some funky frame of a scooter to market the older crowd....lol. This guy in Taiwan sells the seals to convert to the 14mm? crank. http://www.ebay.com/itm/HONDA-Dio-G-Eli ... 1627789446
veedubh20
Re: Honda AF24E
Post by veedubh20 »
af24 use big crank shaft spline.
