belts
Re: belts
Malossi makes a good belt for both the S and the ZX transmissions. Graphie has/can get them.
Meloshameless
Re: belts
I run the malossi belts on my stock elite pulley and my zx pulley, spacing the drive face was required and spacing the tranny cover with some washers. Graphie has the boss spacers too.
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
Re: belts
I found it feels like it grips the pulleys better, believe it or not. My Flash9 has the ZX rear pulley and uses the 18mm version. It's somewhere between the standard 654mm and the 669mm ZX belts, making it ride a bit higher (further from center) on the rear pulley, perhaps good for a little lower gearing and faster take-off. With the oversized 97mm Malossi front pulley, it can also extend the Overdrive at top speed, for a little higher peak speed - over-range at both ends, perfect.
This guy has a new one for $15. If I didn't already have a spare, I'd jump on it.
