Speedo Not Working 85 CH150D
Posted: Thu Nov 17, 2016 11:26 am
by kjkenney
So I'm used to the pure analog speedo on my Aero, but this guy has a little more electrical involved in the speedometer, and I'm wondering if I'm overlooking something. The cable itself seems fine, I unattached it from behind the panel and spun the front wheel and the inner cable spins freely and smoothly. I tightened it back in snug and still nothing. Checked the Reed switch for the digital speedo and it looks fine and clean, but just purely inspected visually. The trip meter and the odometer are analog, and they don't work either. So I'm wondering, is there something in the circuit that could cause nothing at all to work, or is there a chance that the gear that drives the gauges inside the panel is loose or broken? New issue to me, my Aero has all been plug and play, this scoot seems a little more, well, deluxe in its design. Any insight appreciated!
Re: Speedo Not Working 85 CH150D
Posted: Thu Nov 17, 2016 1:44 pm
by MrJumps
My speedo is doing the same. Well, it's a Spree, and it went way faster than its designed to, and well, stripped my gears in my brake hub.
