From Jim's Honda Spree Repair website
Turn your steering bar to one side, look at the frame directly behind the front fender, your VIN number will be printed on a plaque located there.
VIN should resemble:
'84 V.I.N.
49 State: JH2AF060*ES000004~
Engine#:AF05E-2000005~
Iowa: JH2AF061*ES013344~
Engine#: AF05E-2013351~
'85 V.I.N.
49 State: JH2AF060*FS000004~
Engine #: AF06E-2100001~
Iowa: JH2AF061*FS013344~
Engine #:AF05E-2100001~
'86 V.I.N.
49 State: JH2AF060*GS200001~
Engine #: AF05E-2200001~
Iowa: JH2AF061*GS200001~
Engine #:AF05E-2200001~
'86 Special V.I.N.
(Specialty colors: Lolipop Green and Shasta White)
'87 V.I.N.
49 State: JH2AF060*HS300001~
Engine #: AF06E-2400001~
Iowa: JH2AF061*HS300001~
Engine #:AF06E-2400001~
The eleventh digit of the VIN is the year code - E=84, F=85, G=86, H=87.
The ninth digit is a check digit and will vary throughout production.
The eighth digit seems to differ between 49 state and Iowa models. '0' = 49 states (unrestricted), '1' = Iowa (restricted)
How to Tell the Year
Moderator: FAQ Moderator
Reason: Additional info from "Roone140"
