86 Honda Aero 50 rear shock options? Now with performance Q
Posted: Sat Dec 24, 2016 8:12 pm
by coctailer
I think the rear shock on my Aero 50 is the same one it left the factory with.
I'm getting some bottoming out and would like to replace it with a newer/stiffer shock.
Got any direction to point me?
This is a bone stock unmodified original scooter.
Re: 86 Honda Aero 50 rear shock options?
Posted: Sat Dec 24, 2016 8:46 pm
by eclark5483
Motoforce ST1 should fit
Posted: Sat Dec 24, 2016 9:23 pm
by MrJumps
You think that shock is bad, mine bottoms out when I sit on the bike and when I hit a bump my c2 feels it. Lol get it replaced asap bottoming out can crack the frame. Mallossi makes solid stuff, cost a pretty dolla but its worth the holla.
Posted: Sun Dec 25, 2016 5:47 am
by coctailer
graphite9 wrote:ive got alot of really affordable ones on my site. I have the motoforce on my dio, and needed it stiff. sucker barely moves, im really impressed with it for the money
Sweet. I didn't know those ones were drop in for Aero.
Is this the one I need?
http://www.scooterswapshop.com/collecti ... rear-shock
Posted: Mon Dec 26, 2016 7:20 am
by coctailer
And as long as I'm loading up a shopping cart, would I benefit by getting a Dr Pulley slider kit?
How do I know what weight to get?
This Aero will stay pretty much all stock, but I don't mind dropping in a couple performance bits to eke out a little more juice
Posted: Mon Dec 26, 2016 11:14 am
by eclark5483
Actually, I think you need to 245mm, I could be wrong though. Just measure from bolt hole to bolt hole and that will tell you what size you need.
For instance, on my Spree, I measured from the center of where the bottom bolt goes, to the center of where the top bolt goes to come up with 245mm
Posted: Mon Dec 26, 2016 11:19 am
by eclark5483
coctailer wrote:And as long as I'm loading up a shopping cart, would I benefit by getting a Dr Pulley slider kit?
Generally, lighter weight will give you higher revs, heavier weight will give you more torque... this isn't
ALWAYS true, but it's an average guideline.
Re: 86 Honda Aero 50 rear shock options? Now with performanc
Posted: Mon Dec 26, 2016 7:28 pm
by coctailer
graphite9 wrote:i have 245 too.
Looks like the 245 is out.
You got a stash hidden in the shop yo?
Posted: Mon Dec 26, 2016 7:57 pm
by eclark5483
Here are a couple links to other vendors, although they are both in Canada
http://scootertuning.ca/en/suspensions/ ... 245mm.html
http://ultrascoot.com/shock-absorber-mo ... 245mm.html
A google search might yield you better results.
Re: 86 Honda Aero 50 rear shock options? Now with performance Q
Posted: Wed Oct 16, 2019 10:41 am
by Brivander
I need an Aero for my wife, who's got one?
