spree started bogging at take off after belt change
Posted: Tue Feb 21, 2017 6:11 pm
by Spreequal
Spree bogging on take off
Re: 87 spree started bogging at take off after belt change
Posted: Tue Feb 21, 2017 6:27 pm
It might not be the belt/transmission. It sounds like the bystarter might not be closing off the enrichener circuit based on the statement: "but only after it's warm and been ridden for say 5-10 mins.". If so it will run very rich, and thus be low on power.
Posted: Tue Feb 21, 2017 7:12 pm
by Spreequal
Thanks wheelmen .. so the bystarter is the enricher on the side of the carb? It does smoke a bit when first started.. but clears up after running and the spree does maintain about 33 mph if I slow dow to do a U turn is when I seems to loose all power. Then it will kick in and run great.
Posted: Tue Feb 21, 2017 7:16 pm
by Spreequal
The power loss is more frequent then running great though. If I can get it up to 5-8 mph it seems to be able to get itself moving.. I'll try replacing bystarter..
Posted: Thu Feb 23, 2017 9:50 am
by jakubman1
Theres a way to test if your bystarter is any good
