Spree Carb passage verification
Ruckenstein
Post by Ruckenstein »
If I stick a wire in this passage hole should it come out of the tube below it?
Or be visible from the mixture screw hole?
Thanks in advance!
Meloshameless
Re: Spree Carb passage verification
Post by Meloshameless »
I havnt personally cleaned one of those carbs, but other stock honda carbs i have cleaned, elite, express, etc it seemed the hole right angles so wire wont go all the way thru. But thats def the best way to clean it. Or at least loosen up the old dirt, go from bowl up also, then shoot carb cleaner to clear it, or soak it..
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
Is that the idle passage?
If so, you'll not get a wire through it without destroying the jet.
Ruckenstein
noiseguy wrote:Is that the idle passage?
Thank you both!
NG, You have just earned yourself another filter purchase when I need one. ;)
