Weird Carb issues?? Maybe Choke?
Posted: Wed May 03, 2017 7:13 am
by RiverSpree
So the other night I took my carb all apart and cleaned it, ported my exhaust, and intake. Took the bike out she started right up and ran like a raped ape.
The problem is I ran it uptown, i let it sit and cool down and it wouldn't start.. I haven't been able to get it to fire since. I am not getting fuel to the cylinder. I have fuel from the petcock to the carb.
I have messed with the air screw and idle screw and can only get it to stumble. Any help??
My idle screw doesn't seem to change the rpm at all, am i missing something?
All stock bike except for the porting.
Re: Weird Carb issues?? Maybe Choke?
Posted: Wed May 03, 2017 1:01 pm
RiverSpree wrote:All stock bike except for the porting.
WHAT year, make, and model ????
Posted: Wed May 03, 2017 1:36 pm
by RiverSpree
87 SPREE.
Posted: Wed May 03, 2017 1:48 pm
by otto-man
If you don't have enough vacuum to pull the gas up to the cylinder, the crank seal behind the drive pulley may have come out.
Posted: Wed May 03, 2017 1:53 pm
by RiverSpree
THE VACUUM IS WORKING. I CAN SEE THE FUEL THROUGH MY FUEL LINE, AND THE BOWL GETS FUEL AS WELL.
Posted: Wed May 03, 2017 2:02 pm
by otto-man
Maybe bystarter is stuck (not retracting when cool)
Posted: Thu May 04, 2017 7:12 am
by RiverSpree
It also defuels when running wide open, and will not stay idling after running hard
Posted: Thu May 04, 2017 9:21 am
by bonesv
It sounds like your porting may have caused an air leak. That will cause it to over-heat and soft-sieze. There is no way to "port" the intake for better performance. It is designed to work as is. All you have done is create a problem. In my opinion. Replace those "ported" parts with original parts and I bet it will run again.
Posted: Thu May 04, 2017 9:27 am
by RiverSpree
Merp.. well that sucks..
I have another spree I will swap parts and see what happens..
Which sucks.. I read a lot of post all over about guys porting exhaust, and intakes and getting better performance.
Posted: Thu May 04, 2017 11:18 am
by otto-man
In your first post, it wouldn't start due to lack of gas to cylinder. Now it "defuels when running wide open". Maybe petcock issues?
Posted: Mon May 08, 2017 4:48 pm
by RiverSpree
update..
I got her to idle, but rev's super high..
no difference when adjusting throttle cable. she also was just all around bogged down.
Since then I can't get her to fire. I have a ton of vacuum if I cover the intake with my hand. It will pull fuel. i can see fuel spraying past the opening and the spark plug is wet.
I am at a loss at what it could be..? Choke?
I swapped the choke with a different one, but same results.
I have spark when the plug is pulled and held to a ground
Posted: Wed May 10, 2017 11:05 am
by otto-man
Are you SURE that the throttle slide is in correctly. The long slot on the slide should be lined up with a small peg inside the carb. If not in correctly, the slide will not go down, causing high rev
Posted: Wed May 10, 2017 1:06 pm
by RiverSpree
Yes.. the throttle is installed correctly..
I know this because, it two me two days and a google to figure out which way it went..
DOH!!
