AF16 aftermarket carb with stock airbox
esmugala
Post by esmugala »
Hello,
I'm to the point with my 2000 elite that I need to replace the stock carb because of temp issues.
I'm looking at aftermarket carbs but I'd really like to avoid the pod filter setup because of noise levels.
Are there any carbs that are easily mountable to the stock airbox?
Malossi 72cc cast kit
Keli Var
9:1 gears
V8 exhaust
Stock carb w/96 main jet
Stock airbox
bonesv
Re: AF16 aftermarket carb with stock airbox
Post by bonesv »
I still have one of these left. I still use these on a couple of my scoots. I have filters also to fit this. The stock elite throttle cable will work on this also. viewtopic.php?f=2&t=32842
