polini corsa big bore kit
Posted: Fri Jan 26, 2007 7:03 pm
by nate_lohs
hey ive seen 2 different polini corsa big bore kits. ive seen 72cc and 70cc. are they both pretty much the same besides for the 2cc's? i think they are relatively the same price too. i called vtcycles to see if they had any but they said they dont get them in very often, anyone know where i could get one?
Posted: Fri Jan 26, 2007 7:47 pm
by MySpree
corsa and contesta, corsa = fast raceing contesta = put put, but still perty fast.
Posted: Fri Jan 26, 2007 8:07 pm
by nate_lohs
im not referring to the contesta kit. im only referring to the corsa. on vtcycles its listed as being 72cc. i called another hawaii shop , cycle imports of hawaii and asked if they had it. they said they did but it was 70cc. did they just think i meant the contesta? and just to verify the part number for the corsa, is it 119.0077/R ?
Posted: Fri Jan 26, 2007 9:31 pm
by MySpree
well, some people are retarted, the corsa is a 72, so if someone calls it a 70, then whatever, its all on peoples opinions, like these bores, arent really what they seem, there usually 2 cc smaller then they say they are, like the 65cc kits for aeros and elite se50s are really 63cc kits, measured it myself plush others have measured.
Posted: Sun Jan 28, 2007 6:04 pm
by xela_p2004
Whats the bore size on that aero kit you measured? I have seen some kits state they have a 46mm bore and some state a 47mm bore.
Posted: Mon Jan 29, 2007 4:03 pm
by Rabbi
I've seen places referring to the Corsa & Contessa as a 68cc kit... is this possible? They had the same product code as other Corsa kits
Posted: Wed Jan 31, 2007 1:28 am
by 85stroka
It depends on the crank, the older elites with a af09 might have a shorter stroke- 87 elite,85-87 aero and the sa 88 elite Lx
But is the stroke is 41.4mm On a 94 and Up Elite S and SR,and the corsa is a 47mm piston that's 71.8cc
But I think strokeitimports.com has it listed as a 40.4 which would come out as 70.1cc ,so it all depends on the crank.
Posted: Fri Feb 09, 2007 11:56 pm
by veedubh20
jog crank 50 is 39.2 mm stroke X bore 47mm = 68cc. 10mm pin.
