I received this free lovely baby from offerUp, so i use it as a tester for any Spree's stuff. I have a chance to converted some cheap chinese's LEDs lights into this...................any questions, suggestions that could share and learn together, would be appreciates!!!
key ON, engine OFF
with camera straight in angle
brake ON
turn signal ON
engine, headlight ON
You need to get a blue headlight bulb to match. While the assemblies a unit, the inner bulb is separate... you can remove it with a dremel and some careful cutting. Use putty epoxy (ala JB Weld) to install new.
Thank you, Gentlemen for good feedback...floorboard and leg-shield, taillight and blinkers was broken and missing pieces when i got it, so i just threw in and made something happen that legal enough ride-able for it.
When i posting this up, my all intentions was to learn and share to someone who interest add-on LEDs on Spree.....The basic setup to LEDs functioning properly not only complicated alone, but costly, times, skills and knowledge. I was lucky enough to find parts and with my limit knowledge, i was able to keep it under $30 budget, still got the job done.....Instead of writing down steps by steps how to, that might have confused you, due to my bad writing English skill, i decided to post up more pictures, some of them might hint you how's it works. Share with me, if you know how to set it up better, parts, anything...Again, thank you for checking out!
