SA50P Installing new gears
I've been looking for a thread about putting in different gears for my 94 SA50P. I'm thinking about getting the 15x42 taida gears from SSS. I haven't been able to find any information on how to install them.
Currently own:
->1995 Honda Elite 50 (Derestricted)
Have previously owned:
->Multiple 94-01 Elite 50s
->1985 and 1986 Honda Sprees
->1985 Honda Aero 50
Re: SA50P Installing new gears
Check diagram, you are changing Gears C & D: http://hondaspree.net/wiki/index.php5?t ... ion_Ratios
Remove Plastics, Exhaust and rear wheel.
Remove Belt covers and Clutch assembly
Remove gear cover
Remove old gears
Gear C is easily changed by hand
Gear D requires a hydraulic press to remove old gear and press gear D onto the axle
Remove all remnants of old gasket on motor and gear cover. Be sure surfaces are clean and smooth.
Re-install all gears into motor.
Be sure all Thrust washers are in place EXCEPT the one that goes against the gear cover on shaft C
Re-install gear cover with fresh gasket...the use of gasket goop is a personal choice.
Tighten gear cover bolts to proper specs and check to see if axle spins freely by hand.
Fill with recommended oil to proper level.
Check for leaks.
If spins freely and no leaks....reinstall clutch, belt covers, rear wheel, exhaust, plastics....BRAAAAP.
Remove gear cover
Remove old gears
Check for leaks.
What is the recommended level to refill the gear case?
Currently own:
90cc's (3 US oz)
Page 9-6 in the Service Manual
http://www.hondaspree.net/other/SA50_88-02_service.pdf
Thank you.
Currently own:
