I brought this lil baby home last night and it is an excellent example and looks new. I found it on Craigslist like most items. Just an fyi, I bought an 85 Spree with a blown motor 1990 for $50. I fixed the motor and sold it for a profit. 27 years later I am 48 years old and bought my second Spree. It even came with the original Honda key and owners manual.
With the AF05e swap, I can hit 42 mph with my 245 lb butt riding it. Just think if I lost 60 pounds, it would be even faster
Here is the mod info I got from the previous owner, who owned it for 3 years.
Motor
AF05e from an 87' Honda Elite S.
Transmission
These motors had two gear ratio options: 11:1 and 10.2:1...Yours is fitted with the much more rare 10.2:1 for higher top speeds. Gear case was filled with full-synthetic about 400mi ago.
Carburetor
Stock Honda "Keihin" carb. Came stock on the SE50 Honda Elite motor. Recently cleaned and replaced all gaskets and float needle. Main Jet has been upjetted from stock #82 to either an #87 or #90, cant remember exactly. This was done to accommodate the addition of the UNI pod filter. It keeps motor temps in the "safe" zone while allowing it to rev out at wot. This motor was tuned with reliability in mind.
Belt/Pullies/Variator
The belt is a stock Honda "Bando" belt. It was replaced about 200mi ago.
The Variator (front pulley) is KOSO brand for better acceleration over stock and the ramp plate is a Honda "US2" plate sourced from a 1985 Honda NB50 Aero (also rare and regarded as the best ramp angle for top speed.)
Exhaust
Stock, unrestricted-type from an 87' SE50. Obvious from the bulge in the down pipe.
Rear Shock
Rear shock is stock from an 87' Elite SE50. The shock mount location has been moved forward to achieve the correct angle needed after motor swap. The relocation tab used can be seen here: https://scooterswapshop.com/products/sss-shock-tab-kit
Wheels/Tires
Front wheel is a stock Spree type. It has an inner tube It is fitted with a Shinko SR560 80/90/10 tire (largest possible fit between forks)
Rear wheel is from a 2006 Honda Metropolitan. These wheels are commonly used on Spree/Elites to take advantage of their tubeless capabilities. Therefore, your rear tire is tubeless. Fitted with a Shinko SR560 90/90/10. Again, largest possible to fit.
Both tires were new about 300mi ago.
Kickstand
I only mention this because it was an expensive add-on. The motor swap on the Spree comes at a price, and that price is losing the ability to use the stock Spree center stand. It basically renders its mount point un-usable. The solution is a quite pricey KITACO side stand. Many people try to cobble together their own stand to avoid the high cost of this one but none of them work (or look) as good as this one.
Floormat
The Spree Rubber Floormat supply had dried up 25 years ago. Just recently a fellow scooter forum member out of Missouri began reproducing them. I purchased one from him.
Glovebox
A truly rare item. The only ones for sale on Ebay are "completed items" and none currently for sale. One sold for $85 and the other for $90. Neither one of those is as nice as yours. Dull finish, missing stickers, etc.
Air Filter
UNI pod filter UP-4112AST. It has been flow-restricted with caveman engineering. Looks shade-tree but performs excellent.
Here are the pics I took before unloading it from my truck. Click a pic to enlarge it.
