85 spree muffler mod
reitmeyer
Post by reitmeyer »
My stock exhaust is missing the final tube that comes out of the body of the muffler. Just a 1" hole there. Runs loud. I was thinking of adding a silencer. Looking through the hole into the body of the muffler, I see a 1/2" tube. Would I need to connect directly to that or do I weld to the conical back of the muffler?
spree muffler.jpg (94.03 KiB) Viewed 9173 times
Jonadz
Re: 85 spree muffler mod
Post by Jonadz »
I would just get a new one, I've played with a few that had been opened up and never got a decent run with any. Looks like you have the heat guard, that's worth more than the pipe in my opinion, mine are all missing that. I have an extra pipe I'm not doing anything with if you're interested.
Jonadz wrote:I would just get a new one, I've played with a few that had been opened up and never got a decent run with any. Looks like you have the heat guard, that's worth more than the pipe in my opinion, mine are all missing that. I have an extra pipe I'm not doing anything with if you're interested.
This man's experience sounds like good advice.
I'd buy a good pipe before wasting time only to find that he was right.
ped
Post by ped »
If money is No Object I would buy a new pipe.
If you have no money, you can weld a short piece of round tube in there. I'm pretty sure it doesn't connect to the other pipe inside. GL
jakubman1
Post by jakubman1 »
Ive got the exact same muffler sitting in the shed if you need it. Ill sell it for cheap cause 1 of the baffles are loose inside. I can hear it rattle unless i squeeze the end of the exhuast then the rattle is gone. Solid peice though to get your spree back on the road. :)
Lemme know
