just in case anyone has a similar setup as my own and is having jetting issues....
i have an 88 honda elite es (sb50), stock exhaust, uni foam pod filter, & stock carb. after installing the pod filter, i was bogging out at 10mph. i drilled out the stock main jet with a #67 drill bit (0.032"), and it runs excellent now. it's a little slower off the line than it used to be but not by much, i'm considering drilling out the pilot to help low speed. and the added top end is well worth it. i haven't taken it for a full road test to get top speed yet but i'll post the results as soon as i do.
jetting specs for my 88 elite es
... drilling out what pilot jet? There's only an idle jet... DON'T DRILL OUT THE IDLE JET.
Admin, Hondaspree.net
There is no low-speed jet on these carbs. That is an idle jet. If you punch it out you'll trash the carb.
