Good day,
I took my motocompo apart last year to give the frame a powdercoating.
Just putting it back together and I'm not sure how to re-assemble the headset bearings? I've got all the parts loose in a bag...but there appears to be a top/bottom and I'm not sure what is the right way.
I assume the spree/Elite has similar headset design with the headset bearings...can someone post a photo or explain how it goes back together?
Thanks!
Motocompo headset bearings (probably same as spree)
- BMX
Re: Motocompo headset bearings (probably same as spree)
Follow the LINK below to a parts fiche scematic of your steering head...
Hope this helps your sort the puzzle...
https://www.cmsnl.com/ncz50-motocompo-1 ... hy_dtQrKt8
- eclark5483
