Stiff Air box/carb connector tube
- sgracer5072
Looking for some helpful advice. I'm nearing completion of reassembly of my 84 NQ50 Spree and found out that the connector tube from the air cleaner to the carb has gotten so hard I can't get it back on the carb. Anyone have any ideas of how to soften it up even temporarily long enough to get it on the carb? Or does anyone have any ideas of where I could find a better one? Thanks for any help you can give me.
- sgracer5072
Re: Stiff Air box/carb connector tube
That's a good idea. I was thinking about soaking it in hot water, but the heat gun ought to soften it up. Thanks!
Using a zip lock bag with armor all coated on the elbow, leave it set overnight. Then an electric hairdryer to really soften it up prior to install.
No doubt there will be other methods and ideas from others
**Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba.... Hunter S. Thompson**
'95 Ducati 900SS/SP
'98 Honda VFR800
'07 Ducati SS800
www.customcarbservices.com
'95 Ducati 900SS/SP
'98 Honda VFR800
'07 Ducati SS800
- sgracer5072
Thanks! All suggestions are more than welcome and appreciated.
- sgracer5072
The heat gun worked perfectly. Thanks for the idea!52much wrote:A heat gun always seem to soften things up for me.
