With that said, I plan to use it occasionally more for fun than anything...and IÔÇÖve been running this unique Stihl chainsaw fuel (edited
Just wondering if I could run that straight and then I donÔÇÖt have to worry about the oil injection not working proper, or the fuel gumming the carb if I donÔÇÖt use it for an extended period.
Or could I add a bit of 2 stroke oil to it to run it 40:1 or so for the first tank cause of the fresh motor???
The motor in the Motocompo is similar to the spree from what I recall.
