Af16 build opinion
Proy
Af16 build opinion
Post by Proy »
Hey guys. New to the 2 stroke world as far as mopeds go and I want to build a mild af16 to swap into my Spree.
I have read up on as much as i can find here and want your guys opinion on if I'm forgetting anything or if I'm on the right track.
I am planning on picking up a af16 that needs crank bearings and figured I'd throw a new crank at it as well. After looking around, I settled on the Malossi full circle crank because I'm not looking to make any case modifications at the moment.
https://www.scooterswapshop.com/product ... 6775325509
As for a bore i chose a polini contessa 72cc bbk
https://www.scooterswapshop.com/collect ... g-bore-kit
Im looking at the stage6 dio crank bearings
https://www.scooterswapshop.com/product ... 6775623301
And finally a jet kit with the malossi dio vl9 reed block.
https://www.scooterswapshop.com/product ... 6775616773
https://www.scooterswapshop.com/product ... 8328706313
If you guys can see anything I'm missing, the advice would be appreciated. I know I'll need a new motor mount and exhaust is in its future. I just want to get the ball rolling on the engine for mid summer.
jakubman1
Re: Af16 build opinion
Post by jakubman1 »
Get the Corsa...
