Malossi 70cc se50?
ansneds
Malossi 70cc se50?
Post by ansneds »
Has anyone tried this kit on a se50 af05 variated engine? Asking for a friend that is interested in buying this:
https://scootertuning.ca/en/cylinders-s ... -af05.html
Currently own:
->1995 Honda Elite 50 (Derestricted)
Have previously owned:
->Multiple 94-01 Elite 50s
->1985 and 1986 Honda Sprees
->1985 Honda Aero 50
Re: Malossi 70cc se50?
Its a solid kit. It certainly perks up the af05. Just dont expect break-neck speed or performance. You should expect 45-47mph tops with better-than-stock pull unless you also upgrade intake/carb/exhaust/variator/clutch etc...then tops around 55.
Before your buddy goes all-in on the af05...give him the ÔÇ£af16 talkÔÇØ.
