For those who's images from postimage are missing
eclark5483
Post by eclark5483 »
If you previously posted an image using postimage and it is no longer showing up. This is a real easy fix. Just go into the post where the image is no longer there and click edit.
Find the image url and replace
Code: Select all
.org
with
Code: Select all
.cc
If you have alot of images to go through like me, I simply used Notepad+, copied the entire thread, then did a find/replace all to get it done lickity split.
