1985 Honda spree clutch question
Hey i just replace the clutch in my spree now at idle the back tire spins. Is there a clutch adjustment or do i dial down the carb?? Thanks all
1984 elite ch125
1985 spree nq50
1986 spree nq50
1987 helix cn250
1985 spree nq50
1986 spree nq50
1987 helix cn250
- eclark5483
Re: 1985 Honda spree clutch question
Springs might be shot. You should be idling at 1800 +/- 100 rpm without the tire spinning.
I just had it religned and they didnt mention springs. They seem fine to me
1984 elite ch125
1985 spree nq50
1986 spree nq50
1987 helix cn250
1985 spree nq50
1986 spree nq50
1987 helix cn250
- eclark5483
Maybe they are, don't want to steer you otherwise. Just saying, it is good practice to put new springs in while you have it all torn apart anyway. Best way to tune, is get a tach. If the wheel never spun before, and you know that you made no changes to what the carb was already set at, then this should tell you that for some reason, the new pads wanna bite down. Check with a tach to see if idle speed is higher then spec. If your idle is within spec and you are turning, then the problem is more then likely springs. On mine, I can bring the rpm up to about 2200 before the springs kick in and the wheel starts to spin. Researching possible ways to bring that more up to around the 3000 rpm mark. The higher up in the rpm's you can get the springs to catch, the faster and smoother the launch.
I did petcock and line never touched the carb.Is it easy to change the springs my self? I have no idea how to take apart
1984 elite ch125
1985 spree nq50
1986 spree nq50
1987 helix cn250
1985 spree nq50
1986 spree nq50
1987 helix cn250
I think you answered your own question.Volvo850R wrote:Is it easy to change the springs my self? I have no idea how to take apart
If you have "no idea", it is not going to be easy.
The process is a bit tricky.
I am not able to give you a step-by-step instruction.
Yielding to the more experienced.
Always wear safety glasses.
When you say 'the wheel spins' do you mean when the wheel is off the ground on the stand? If so, does the engine slow down if you put the back brake on? I'm thinking that maybe the shoes can wear in a little?
It spins when On the stand. If I come to a stop and just hold the back break IÔÇÖm good. I just got it all back together just going to send it
1984 elite ch125
1985 spree nq50
1986 spree nq50
1987 helix cn250
1985 spree nq50
1986 spree nq50
1987 helix cn250
The driven pulley spins freely on bearings, relying on the clutch to secure the connection when RPMs reach engagement speed. There is a certain amount of bearing drag that will slowly spin the output shaft, even with the clutch disengaged. As long as you can stop it without slowing the engine down, you should be fine. If not, the Idle RPM is too high, there's an issue with the clutch, or the idler bearings are getting "catchy".
- eclark5483
Yep, that might be very well it as well. If you can put your foot on it lightly while it is spinning and it stops, then I wouldn't worry about it so much. I like to set my idle at 1800 (warm, and choke not engaged), and go with that. If it's on the ground, and not trying to move forward at idle with the brake disengaged, then you are golden. If it starts to move forward a bit, then something is worn or needs a dab of grease. Don't worry too much about spinning on the stand.. ideally, it won't, all the better if it does, but no biggy for the most part as long as it plays nice on the ground.
If it bothers you, set the parking brake...just dont forget its on if you wanna revv while its on the stand. Like Wheeldude says, its just the needle bearing drag within the Driven Face assembly. Perfectly normal.
- eclark5483
So, to back up a bit here and clarify. Is the replacement clutch one that has been re padded? Is it off of a different Spree? Define replace, thanks. Might help get to the bottom of the issue since you are unskilled in spring replacement. So I'm guessing someone else did the new clutch for you.Volvo850R wrote:Hey i just replace the clutch in my spree
Yes sent to jw clutch werks. Repadded. I have impact gun and vise. Im sure i can get it apart and replace the springs. It does seem like when it on the stand and you apply reae brake the motor rev does come down little bit
1984 elite ch125
1985 spree nq50
1986 spree nq50
1987 helix cn250
1985 spree nq50
1986 spree nq50
1987 helix cn250
Did you try just turning down the idle a touch, at the carb?
Admin, Hondaspree.net
