spree won't turn over after winter storage
MaskedJellybean
Post by MaskedJellybean »
I took my spree out of my garage yesterday after not having run it since November. I was too lazy at the time to do anything to prepare it for storage, so of course it won't start now. I charged up the battery and have tried kick starting it many times. It tries to start but doesn't have much power and never actually turns over. I guess I will try draining and replacing the gas and maybe the oil unless anyone else has any genius ideas? :?:
burnt_toast
Post by burnt_toast »
how can it try to start and not turn over?? that doesnt make sense. please clarify.
have you tried starting fluid?
projects galore :nerd:
HuskieMobileMan
Post by HuskieMobileMan »
Try jump starting it, and if that doesn't work you can try priming it by putting a small amount of gas in the combustion chamber. If that doesn't work, change the gas.
'84 Aero NH125
'84 Aero NH80
'05 Kymco ZX50
islandbayy
Post by islandbayy »
Clean your carb.
Drain half the gas with a turkey baster, and top er off with fresh stuff. Once you get it running, leave it running.
Then, pour 1/4 can of SeaFoam in the gas and leave it run for 10 more minutes. Then take it for a drive to clean out the nasty s***.when you get back, topp of the tank again, and put in another 1/4 can of seafoam.
http://KmanScooters.com
http://MilwaukeeEV.com
