turbo anyone?
- hondaspree86er
- BMX
turbo anyone?
i just got this weird i dea to turbo my spree. i am going to use a k03 turbo off a vw. that is the smallest one i can find. anyone think its possible?
35 mph 1986 Honda Spree with intake mod 2242 miles and excellent plastic
- hondaspree86er
- BMX
I think they make bike turbo's small enough for this... I've never found a source for one though. There was a guy with a turbo Spree posting on here a year ago... never got enough details to figure out what was going on with it.
Admin, Hondaspree.net
- BMX
try checking http://www.michiganturbo.com
if they don't have what you want, they might be able to custom build it.
I asked them this question... we'll see if they can answer it.
I've seen a few 50-100cc bike engines with turbos... I've no idea where you'd get a turbo that small!
- Streetglow
- Goped
- burnt_toast
bet its worth it if it works..Streetglow wrote:I've seen a small engine supercharger kit before, but it costs almost $1000.
as far as on a spree, it' be pretty d*** hard to tune and spool yet still only get you like 40mph haha (maily due to fixed trans..)
But for some motivation, here's a turbo'd 2stroke vespa!
http://video.google.com/videoplay?docid ... espa&hl=en
and thats like 150cc and notice the boost lag!!
projects galore
- BMX
There was a guy i knew in high school that connected a leaf blower to his intake on a scooter and got the scooter going and started the leaf blower and once he got up to speed he gunned the leaf blower and it apparently has some effect on the scooter because it took off like a rocket, I think it did end up messing the scooter up somehow or another....
OK... there's a workable idea... take apart an electric leaf-blower, keeping the fan, fan shroud, and motor. Gut the electrical motor and add a pully in place of the rotor. Hook the rotor up to the fan side of the Spree block and turn it off the crank. Attach a blow-off valve on the fan output and hook it to the intake. Install an air filter on the intake side of the fan, or at least a screen.oncewaslost1982 wrote:There was a guy i knew in high school that connected a leaf blower to his intake on a scooter and got the scooter going and started the leaf blower and once he got up to speed he gunned the leaf blower and it apparently has some effect on the scooter because it took off like a rocket, I think it did end up messing the scooter up somehow or another....
Cheap, readily available non-intercooled supercharging... Since these run on fractional HP electrical motors or sub 50cc engines, the boost/power input should be close... Junkyard engineering at it's finest.
I really like this idea... I'm going to run it by a couple of the PT engineers that I know to find out if it's workable.
- BMX
- burnt_toast
well it is a workable idea, and on small applications like a scooter might really have a chance of working. I've seen someone put a leafblower on the intake of a civic on a dyno and it gained about 20hp over base run, but most car folk think talks of power adders like this are rice..oncewaslost1982 wrote:if you end up doing that then i wanna see pics. It worked on the guys i knew in schools moped. but he didnt do all the engineering you are talking about, he just ran a pipe from the blower to the moped intake and held one throttle with one hand and another throttle with the other hand and took off.
Why this would work however, is a leafblower has an actual compressor fan assembly that would give you some partial boost assuming no leaks. What probably happened with your buddy's scooter is it got the boost of air, but ran lean due to no extra fuel supply. Correcting for the fuel mixture somehow would be ideal to make it work.
I had some ideas of doing this on my car after seeing how it worked on the civic, but decided it wouldn't be worth it if I messed up.
Noiseguy talk this over and let us know what you find out!
projects galore
- burnt_toast
a fan isn't the same as a compressor, it will just push ambient air into the intake. but on an engine that small you could see some gains. But for a 50cc+ scooter a computer cooling fan wouldn't be enough to create boost imo.wbpolk wrote:you know what also work..... a computer cooling fan. they are really powerful and they dont use that much power.
well it worked on my buddies 29cc goped.
projects galore
