kick assembly
Posted: Thu Mar 22, 2007 4:49 pm
I replaced kickstart assembly last year cause original part had worn teeth and driven gear, sure wished the electric start would work, anyways the used but functional assembly now has worn teeth, even worse than the original, but still has a better driven gear...should i try to swap out or should i just bite the bullet and purchase a new sprocket piece? i am not too sure how i would get the spring thing correct, but i'm willing to try...also, there are abrasions inside the crankcase, as if the piece is striking it, is there some adjustment i should do?
