Page 1 of 2
tuning advice
Posted: Sun Mar 25, 2007 3:35 pm
by nate_lohs
ok i need some pointers on tuning my scooter. ive got it so that it accelerates good but the top speed should be higher. here is my setup
elite S
dio with 72cc bore
8.4:1 final drive gears
high speed pulley with 9 gram weights
1000 rpm clutch springs
1500 rpm compression spring
running stock carb with 90 main jet. using stock airbox and running premix
50:1 ratio
r1 exhaust
it goes faster than the stock speedo can read. but it seems to only reach like 45. i know that a lot of people with this same setup are reaching better top speeds. anything you guys notice that i could change?
Posted: Sun Mar 25, 2007 8:09 pm
by xela_p2004
Open up your airbox and rejet the carb.
Posted: Sun Mar 25, 2007 8:35 pm
by nate_lohs
so you think my trans set up looks ok and that my stock air box is restricting me now? maybe ill order an aftermarket filter for it and a couple jets. any more advice?
Posted: Sun Mar 25, 2007 9:34 pm
by noiseguy
I think that you could probably play with the trans more... but you need to find someone that knows more about those...
Posted: Sun Mar 25, 2007 9:51 pm
by hrnytrtlsgsxr
to me you should first try to lower your weight. the 15% spring set up usually comes around 36-42G. i dunno what spring is 1000 but i like the pollini green with the 15% center spring.
Posted: Mon Mar 26, 2007 2:12 pm
by nate_lohs
ok ill lower the weights a little and see how it goes. btw where do you get those specs for what weight should go with what compression spring? or do you just know from experience?
Posted: Mon Mar 26, 2007 10:09 pm
by nate_lohs
ok i put the weights at 39 grams. it accelerated ok but top speed was really low. like 35mph. i had a 6 pack of 9.5 gram weights so i threw those in and it seemed to accelerate good and top speed was better. it almost went past the mph mark on the speedo. im guessing close to 50 maybe. now im not sure if i should lower the weight or raise it or leave it or what.
something else i noticed is that im using a ton of gas. im on empty after a little over 30 miles. so im probably running really rich.
any thoughts?
Posted: Mon Mar 26, 2007 11:31 pm
by islandbayy
Did you change your main jet also?
And for everyone else, to get higher top speed, which do I want? Higher or Lower weight weights? I think i have stock in right now but i have a whole bunch.
Posted: Mon Mar 26, 2007 11:54 pm
by nate_lohs
i did not change my jet at all. i only have 2 jets, the stock jet and a 90 jet. would i be better off getting an aftermarket air filter?
Posted: Tue Mar 27, 2007 2:01 pm
by MySpree
u bury my speedo to were it hits teh bottom of the speedo case and i have gears and a hp pulley kit...
Posted: Tue Mar 27, 2007 2:25 pm
by nate_lohs
MySpree wrote:u bury my speedo to were it hits teh bottom of the speedo case and i have gears and a hp pulley kit...
thanks for the advice.
Posted: Tue Mar 27, 2007 7:34 pm
by MySpree
im saying that just as something to work with. if with all that stuff you cant even reach the bottom of the speedo then there must be a problem. you need a bigger main jet and im running all 13s in my elite... and i can still wheelie from a stop. aka crazy accel still
Posted: Tue Mar 27, 2007 7:54 pm
by nate_lohs
youre running all 13 gram weights? what size compression spring are you using? i was also wondering what the reasoning behind the bigger jet is, just cause i think im running a little rich already. maybe i should get an aftermarket air filter and ditch the air box. man that would be cool to wheelie from a stop. oh and what kinda gas mileage should i expect with my setup. ive been getting around 30mpg.
Posted: Wed Mar 28, 2007 4:12 am
by W/C
I just retuned my friends bike, 8.5 grams x 6 , 1000 center spring, kelli clutch with stock springs that comes with clutch, stock pipe,stock carb,daytona pulley, stock ramp 45mph but it's locking up the gearing
Posted: Thu Mar 29, 2007 7:50 pm
by nate_lohs
hey myspree. could you post up what you have done to your scooter and what your trans setup is, like what springs, etc.
