Replacement 44mm bbk Rings?
ASpreeOfJoy
Post by ASpreeOfJoy »
Does anyone know where I could get rings for the 44mm big bore kit? I will be in possesion of one soon and would like to make sure i can get rings if i need to. The kit itself is new.
Re: Replacement 44mm bbk Rings?
What kit is it?? Cant you ask the seller if they sell rings for their kits? There are more specifics to rings than simply their diameter.
ASpreeOfJoy
Meatball wrote: Mon Aug 20, 2018 9:45 am What kit is it?? Cant you ask the seller if they sell rings for their kits? There are more specifics to rings than simply their diameter.
The kit is coming from a local guy it has instructions about cutting the head but I didnt hear a brand yet. Worst case I was going to measure the piston and rings with digital calipers and order the closest thing from husqvarna.
Good luck wit dat.
ntonar
Post by ntonar »
Meatball wrote: Mon Aug 20, 2018 4:06 pm Good luck wit dat.
Right, there is a bit more to than the diameter of a piston.
ASpreeOfJoy
I'll have the original rings in my possesion to measure, I've been watching videos on ring filing for a perfect fit. The rings are only incase I need a rebuild in the future if I mess the kit up.
